Web AppBuilder Install Nightmare
36520
30
12-22-2014 03:29 PM
AndrewMilanes
I can't seem to get the released version of Web AppBuilder installed as a service.  I had to change to port 3347, since the beta version ran on 3344.  Don't know how to release that port.  I can get the new version running from the startup.bat file after changing the port.  I can also get the service installed, but it won't start.  Is it because it's trying to use port 3344?  Where can you change the port when you install as a service?
This install is a major pain in the rear.
MattReames1
Evidently this is still a problem.   I would call it a bug in the WAB-Dev startup.bat.
startup.bat tells me port 3344 is in use,   when it isn't.    It is detecting a false positive based on a process ID with the number "3344", not the port 3344.
When I kill the process ID  #3344,  the startup.bat works again.
