web app builder not working in local host
10895
19
02-07-2019 05:54 AM
khaniqbal
i make a application with web app builder 2.11 (developer edition).when i run bat file its working but when i download  & deploy in localhost its give a error in browser (ERR_CONNECTION_REFUSED).first time i am using WAB,i am using win7.
khaniqbal
this is console errors log
RobertScheitlin__GISP
Khan,
  Open the apps config.json in the main folder in a text editor and change the "portalUrl": to a http url instead of https.
Also add the woff and woff2 mime types to your web server.
https://manage.accuwebhosting.com/knowledgebase/2443/How-to-set-MIME-types-for-web-fonts-in-IIS.html
khaniqbal
thanks both errors fixed. now another one error.how can fix?
khaniqbal
Thanks my problem is solved.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
rajaparlindungan
how to solve this problem?
RolandoFernandez
Hello Robert, I'm unable to use WAB. It just get stuck on this screen when I try to create a new app.
I already asked for help to the Esri represents that sell us the license in my country (Venezuela) but I have been waiting their answer for more than a month.
I got a Creator user and a GISPro Basic license, with any of those users I'm unable to use WAB.
I already tried with different browsers, eliminate cache, and enable pop up and cookies.
I hope you or someone in the Esri community can help me with this.
Thank you in advance.
AndresCastillo
Robert Scheitlin, GISP Champion , am I right in thinking that NodeJS as a web server deploys WAB Dev Ed. apps only within the same network connection?
In other words, it wont serve the apps out like IIS would over public ip's.
For example, I wouldn't be able to access the apps served out by the NodeJS web server that's on my local network from my mobile device carrier's network.
I would need IIS for this desired behavior.
Andres,
   Yes that is correct NodeJS web server will only work on the same network. You need IIS on a web server that has a publicly accessible IP.
PradeepNagu
Hi all i'm new to ESRI Arcgis
I created the web app using the web app builder developer edition and i deploy on local windows IIS and hitting the URL  it throwing the Error of CORS Policy.Even i added the Access-Control-Allow-Origin:* header response could please anyone help me out what should i do.
Thanks in advance.
