WAB Printing Legend issues: Query Result Layer
13841
25
01-18-2016 11:26 AM
MonikaHonkova2
Hello,
I created a query using the Query widget and added the result as an operational layer to my map. The legend looks ok in the Legend widget but I don't understand why it's showing a label "Override 1" next to the legend patch in the printed map.
Also as you can see on the attached image, the symbol for the original map layer (polygon, no fill, pink outlines) is missing from the legend.Capture.PNG
Is there a possible solution? Monika
Noah-Sager
Are you still facing this issue? I cannot speak for the Web AppBuilder, but I believed we fixed this issue with the ArcGIS API for JavaScript back at 4.14: https://developers.arcgis.com/javascript/latest/4.14/#bug-fixes-and-enhancements
LarsDe_Sloover
Hi @Noah-Sager , thanks for your quick response.
I was talking about the Web AppBuilder indeed, not the API for JS. My bad.
I found the same issue here: https://community.esri.com/t5/arcgis-online-questions/arcgis-online-print-widget-pdf-legend-name-dis...
If necessary, I can continue the thread on the link above?
Thanks
Lars
Noah-Sager
I think that would be appropriate. I know it gets complicated sometimes. Thanks.
TanuHoque
Thanks @Noah-Sager for quick response.
@LarsDe_Sloover  can you pls share your repro steps/webmap etc. with us? I can take a look. thanks
Tarunvisvanadula1994
I'm Facing Similar kind of issue in WAB Application. I have used Feature collection to add selected features as feature layer on map.
Do we have any solution for this issue ?
JavaScript API 3.31
Thanks in Advance
tahunt01
Hello, I am currently experiencing this same issue. I am using a combination of map viewer classic, web app builder, and a custom print service that I published. Everything about the print service works as it should, except when I generate a query layer. Regardless of what I name the result layer, it appears in the printed map legend as "Override 1". Is there a way to fix this?
