WAB eSearch "parcel between x and y"
1392
09-22-2016 08:11 AM
WilliamBailey
Rich,
I see Flexviewer eSearch posts mentioning "between" queries.
I have need in WAB for sql like this:    " Parcel between 'x' and 'y' "
Will result in collection of parcels based on a range where x and y are typed in by user.
Please point me in the right direction.
p.s. Keep up the good work on your widgets, love em.
RobertScheitlin__GISP
William,
   Yes you can. What does the SQL look like?
William,
   If you are searching by a numeric parcel number the you can easily do a greater than x AND less than Y query in the WAB eSearch widget. just add two expression values when using the settings dialog for the query expression.
WilliamBailey
Parcel is a string, query works in TSQL.
Can I edit config_Enhanced Search.json in configs\eSearch ?
William,
WilliamBailey
All is working as expected, thanks again
TSQL:
where parcel_key >= '1720305TH00000000' and parcel_key <= '18203030099999999'
Config:
"fieldObj": {
"name": "PARCEL_KEY",
"label": "PARCEL_KEY",
"shortType": "string",
"type": "esriFieldTypeString"
"valueObj": {
"value": "Low Parcel Number"
"prompt": "PARCEL_KEY is >=",
"textsearchhint": "Low Parcel Number",
"sqltext": "Upper(PARCEL_KEY) >= Upper('[value]')",
"operation": "stringOperatorIs",
"required": true
"fieldObj": {
"valueObj": {
"value": "High Parcel Number"
"prompt": "PARCEL_KEY is <=",
"textsearchhint": "High Parcel Number",
"sqltext": "Upper(PARCEL_KEY) <= Upper('[value]')",
"operator": "AND",
"required": true
