WAB 1.2 Node Upgrade error (from WAB 1.1)
6700
10
08-12-2015 08:31 AM
GeraldLee_
I have downloaded the new WAB 1.2 dev edition and it launches fine, but when i try to run the upgrade command line utility, im getting this error:
"Cannot find module "c:\arcgis-web-appbuilder-1.2\upgrade".
i have closed out all open instances and ran it again and still get the same error.
Can i manually upgrade Node.js from its website or is this module just missing from the download? I also do not see any "upgrade" module under the c:\arcgis-web-appbuilder-1.2\node_modules folder.
I've tried copying over the existing apps.
I've tried zipping them up and importing them into 1.2 version but i received a "parsing error" upon attempting the import.
Running Win 7 SP 1
Thanks for any insight,
Gerald
ZacharyOrdo__GISP
I did the exact same thing...forgot to change to the \SERVER directory.  Once I did that, it worked immediately.
