Updated symbology in hosted feature layer not reflecting in WebApp map
7110
11
06-22-2021 08:19 AM
GISLearner
I have a webapp map that contains multiple layers and some of those layers' data are updated weekly or monthly. Never causes an issue. This time, I updated the symbology of one layer, but the symbology is not reflected on the webapp map. When the layer is turned on, the update before updating the symbology appears. I've tried removing the layer widget and adding it back, but that doesn't do anything. Any help on how to fix this would be highly appreciated.
GISLearner
The WebApp Builder is tied to a web map. The solution was to edit that web map -- remove the layer and re-add it. Thanks @AnnaStam and @JayantaPoddar
NileshShingade
its not working. i tried everything. even i published new web map with different data. still its not showing the symbology in web app builder.
