Smart Editor Intersect - Can you add multiple values to intersect field?
1080
02-02-2021 12:39 PM
cardiofaz
I am using the smart editor for it to intersect against other datasets.
I am trying to figure out is it possible where it intersects against more than one value, that all that information then feeds into the field you have identified.
So output after you use editor to draw i.e a polygon and the output comes out with 3 values. Those 3 values then appear in the field selected.
Output = Value1, Value2, Value3
AlixVezina
Hi @cardiofaz,
The Smart Editor widget does not support concatenating values in the target field when using intersection attribute actions - only one value can be added to the field.
