share widget shortlink leads to arcgis.com
10500
18
10-03-2016 03:04 AM
AnninaHirschi_Wyss1
I'm wondering if this is a bug or a feature or if it happens only to me.
The shortlink in the share widget in Web AppBuilder leads to my App but with the general arcgis.com URL instead of my AGOL subscription.
Does anyone experience the same?
Do you find that correct?
I would very much prefer that the resolved URL reflects my subscription.
Annina
LemaoWu
Hi Annina,
This enhancement will be implemented in the April update. Thanks.
XanderBakker
Esri Esteemed Contributor
Strange... I just added the Share Widget and the resulting URL includes the AGOL subscription:
Does your URL work? Is it redirected to your AGOL subscription?
AnninaHirschi_Wyss1
Xander,
Thanks for checking.
Are you using WAB Dev or built-in? I'm facing the issue with the online built-in, haven't checked yet the Dev version.
The link is redirected to the correct app, but with the URL showing the global arcgis.com without the AGOL subscription.
XanderBakker
This is the standard ArcGIS Online versión of WAB.
AnninaHirschi_Wyss1
Very weird, I did not get a solution yet for this... Keep inquiring.
AnninaHirschi_Wyss1
here also the same on another subscription:
LemaoWu
Annina - If your app is shared as public, the URL will use http://www.arcgis.com instead of your org URL. A related instruction of AGOL FYI: Share items—ArcGIS Online Help | ArcGIS
AnninaHirschi_Wyss1
LWu-esristaff‌, Thank you for this, but doesn't this only apply if anonymous access is disabled? The concerned subscriptions allow both anonymous access...
http://esri-rw.maps.arcgis.com
http://mininfra-geoinfo.maps.arcgis.com
LemaoWu
Annina, There is no privilege to check if anonymous access is disabled or not from a pubic app however.
AnninaHirschi_Wyss1
But, then why other (built-in) share links, e.g. the Story Map here http://arcg.is/1YGN6Ep do correctly lead to the subscription URL: http://esri-rw.maps.arcgis.com/apps/MapTour/index.html?appid=b9c94764182e46949210f292cad94a47 ? Why does my WAB share widget not work in the same way?
