Screening widget - printed report
536
05-25-2022 06:36 AM
SarahNoakes1
Occasional Contributor II
I'm looking at building a Web AppBuilder site using the screening widget.  It does pretty much everything I want, but I have one major issue with it -  the time it takes to generate a printed report. The tabular data appears instantaneously, but the map takes an age to produce. It's slow enough to be a show-stopper.
Is it possible to configure the report to not display a map?  Or display a smaller, lower quality image?  I see you can change the print service URL, but I haven't managed to make that work as yet.
Sarah
Cornwall Council
Tags (1)
CarmellaBurdi1
New Contributor III
Hi Sarah,
Did you ever figure this out? I would love to remove the map from my report output, too. 🙂
SarahNoakes1
Hi @CarmellaBurdi1 ,
We logged the issue as a case with ESRI UK and in turn, they logged a couple of enhancement requests with ESRI Inc. - one of which is ENH-000153167 - Provide the ability to print a report from the Web AppBuilder Screening widget without including the associated web map.
Regards,
Sarah
CarmellaBurdi1
New Contributor III
Thanks so much!
