Print widget not printing basemaps
4691
7
05-08-2019 09:24 AM
KafilBaig
I am trying to print a map from the print widget it prints the layers on the map . But it doesn’t print the basemaps. Is anyone having these issue or anyone have solution for this . Should I configure anything else for the print widget to work for basemaps .
I am using wab 2.8 embeded with portal for arcgis 10.6.1
Tags (1)
SteveCole
Honored Contributor
I have this problem as well. We are using Portal 10.7.1 and whatever WAB that comes with that and the feature layer (hosted in Portal) prints on the maps but neither the ESRI Vector basemap nor an imageServer service hosted on our 10.61 Image Server will show up in the resulting PDF.
WalterSimonazzi_VicPol
I'm having this issue. Did you manage to find a solution for it?
SushilPradhan2
Hi, I am having the same issue, so please let me know if you have found the solution yet?
JulianeStraub
Hi, we're having the same issue by using basemaps with another coordinate system than wgs84. Is there a solution for this problem? @esri
SarahL
Also having this issue in WAB, but works fine in Experience Builder. Just made a new vector tile basemap. Portal 10.8.1.
OliverIshmael
We are also having the same problem. Does ESRI monitor these forums?
apgis16
Having this issue now in ArcGIS Enterprise with a map image layer in the basemap.
