JQueryUI and KendoUI don't work in Web AppBuilder ?
4160
09-30-2015 11:10 AM
casey--cupp
Super Simple sample of autocomplete using Jquery and KendoUI (free core)
works fine in sample... http://plnkr.co/edit/BBYXwehUX9cGIbmev2Tf?p=preview
but doesn't work in Web AppBuilder. (I've tried setting it up in postCreate and startup also)
Widget.html
<div>
    <p>Kendo UI Animal:  try A or B <input id="animal" /></p>
    <br />
    <p> jquery UI colors: try R or B
        <input id="autocomplete1" type="text" name="code" />    </p>
</div>
Widget.js
define(['dojo/_base/declare', 'jimu/BaseWidget'],
function(declare, BaseWidget) {
  return declare([BaseWidget], {
    baseClass: 'jimu-widget-demo',
    postCreate: function() {
      this.inherited(arguments);
      console.log('postCreate');
    startup: function() {
      console.log('startup');
    onOpen: function(){
        console.log('onOpen');
        if ($("#autocomplete1").autocomplete !== undefined) {
            $("#autocomplete1").autocomplete({
                source: ["red", "blue", "green"]
        if ($("#animal").autocomplete !== undefined) {
            $("#animal").kendoAutoComplete({
                dataSource: ["Ant", "Antelope", "Badger", "Beaver", "Bird"],
                change: function () {
                    alert("aA");
casey--cupp
The html above is showing html, i wanted to include the actual html.. so here it is..
<div>
    <br />
    </p>
</div>
casey--cupp
Actually after a few more tests it started working.. not sure why..
JamilNawaz
Can you please explain me how did you integrate kendo ui? I mean where you put its JS and css files and how loaded into your widget?
Regards,
Jamil
BradleyNeish
Hello,
Has anyone been able to integrate Kendo UI into a Web Appbuilder widget yet?  I have tried to both run a script in the HTML template which doesn't seem to fire and I have tried to run the code in the widget JS file but I always get a 'is not a function at Object' error.  I have tried to add references in the index.html as scripts references and in the init.js in the resources array.
Brad
