Internal ONLY Web Map Sharing Issues
41844
91
09-25-2015 08:36 AM
BrianO_keefe
Honored Contributor
So we have a webmap that is INTERNAL ONLY. We have to build the 'ArcGIS' map side online, then using WAB build the web map, prop it up on our internal server, and now it's asking for AGOL sign on. This is supposed to be used by Field Crews?! They will 'never' have AGOL accounts... what is the proper workflow for a situation like this?
RobertScheitlin__GISP
Alba,
   Sorry I missed that you did not have the proxy rule for route in your config.json
and my app config.json proxy:
"httpProxy": {
  "useProxy": true,
  "alwaysUseProxy": false,
  "url": "/DotNet/proxy.ashx",
  "rules": [
    { "urlPrefix": "http://albavoli.maps.arcgis.com/", "proxyUrl": "/DotNet/proxy.ashx" },
    { "urlPrefix": "http://route.arcgis.com/", "proxyUrl": "/DotNet/proxy.ashx" },
    { "urlPrefix": "http://traffic.arcgis.com/", "proxyUrl": "/DotNet/proxy.ashx" }
albavoli
Robert thanks but it needed also logistics.arcgis.com so i added also that in the proxy and app config but i get this now
Alba,
   So did you add logistics url to the proxy.config?
albavoli
Yes
<serverUrl url="http://logistics.arcgis.com"
                   clientId="xxx"
                   clientSecret="xxxxx"
                   rateLimit="600"
                   rateLimitPeriod="60"
                   matchAll="true"/>
Alba,
   Notice that your error states that the URL is https:// for the logistics dot arcgis dot com. So you need to change your proxy config to be https.
albavoli
Thanks Robert it works
albavoli
Robert i have another question how can i access a private map using proxy without the login appearing can u help me?
Alba,
   That was the original posters question and it has been answered in this thread already.
albavoli
But i am accessing a private feature layer from another organization and used it in my web map
Alba,
   That means that you have to add the serverURL to your proxy.config and also add that url to your proxy rules in your config.json
