Internal ONLY Web Map Sharing Issues
41677
91
09-25-2015 08:36 AM
BrianO_keefe
Honored Contributor
So we have a webmap that is INTERNAL ONLY. We have to build the 'ArcGIS' map side online, then using WAB build the web map, prop it up on our internal server, and now it's asking for AGOL sign on. This is supposed to be used by Field Crews?! They will 'never' have AGOL accounts... what is the proper workflow for a situation like this?
BillFox
MVP Notable Contributor
Hi Brian,
I would install Portal for ArcGIS on-site, federate it with your ArcGIS Server site, Web Adaptor/SSO & SSL to on-site geodatabase and have your field crews use VPN.
Then you would have everything in your hands.
-Bill
MichaelRobb
Honored Contributor
Would not federate Server with Portal.  There are only a few reasons to federate and none were addressed / discussed by Brian.
