Internal ONLY Web Map Sharing Issues
41831
91
09-25-2015 08:36 AM
BrianO_keefe
Honored Contributor
So we have a webmap that is INTERNAL ONLY. We have to build the 'ArcGIS' map side online, then using WAB build the web map, prop it up on our internal server, and now it's asking for AGOL sign on. This is supposed to be used by Field Crews?! They will 'never' have AGOL accounts... what is the proper workflow for a situation like this?
BrianO_keefe
Honored Contributor
In the config.json.
On line 290.
Where you enter the rules like so...
"rules":[
You said to enter like you said to enter... and I did...
I didn't pay attention to the squiggly brackets...
The damnable squiggly brackets...
I just inserted them and VOILA!
it works...
I'm torn between ecstatic-ness... and facepalm-ing.
Thank you so much man. Friggin details.
albavoli
I use the same configuration but when I change my config.json httpProxy it shows a blank page.Can anyone help me?
RobertScheitlin__GISP
Alba,
   What does your browsers web console say?
albavoli
I have done some error in configuration and now it opens but when i click on get direction widget it opens login again and the problem is that route.arcgis.com gives :
Error: Token Required.What is the configuration for that because in proxy.config i have put my client id and secret?
Alba,
   Do you have the http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World url setup in your proxy.config?
albavoli
no i am using
<serverUrl url="http://route.arcgis.com"
                   matchAll="true">
                  clientId="xxxxx"
                   clientSecret="xxxxx"
                  rateLimit=120
                   rateLimitPeriod=60
        </serverUrl>
Alba,
   Sorry that is what I asking. This is what I have and I do not get challenged:
                   clientId="my client Id"
                   clientSecret="my client secret"
                   rateLimit="600"
                   rateLimitPeriod="60"
                   matchAll="true"/>
        <serverUrl url="http://traffic.arcgis.com"
                   rateLimit="600"
                   matchAll="true"/>
albavoli
my proxy.config is:
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
             mustMatch="true">
    <serverUrls>
        <serverUrl url="http://albavoli.maps.arcgis.com
                   username="xxx"
                   password="xxx"
                   matchAll="true"/>
        <serverUrl url="http://services.arcgisonline.com
                   matchAll="true"/>
                   clientId="xx"
                   clientSecret="xxx"
                   rateLimit="600"
                   matchAll="true"/>
                   clientId="xxx"
                   rateLimit="600"
                   matchAll="true"/>
       <serverUrl url="http://myserver
                   matchAll="true"/>
    </serverUrls>
</ProxyConfig>
and my app config.json proxy:
"httpProxy": {
"useProxy": true,
"alwaysUseProxy": false,
"url": "/DotNet/proxy.ashx",
"rules": [
{ "urlPrefix": "http://albavoli.maps.arcgis.com/", "proxyUrl": "/DotNet/proxy.ashx" }
What i am doing wrong?
Alba,
   Is your app running in http or https?
albavoli
http
