Customizing Incident Analysis
1464
02-17-2021 04:51 PM
DSpencer
Hi, This feels like it should be easy but I am having no luck. I am trying to edit the code for the Incident Analysis widget so that when I create a buffer it remains after the widget is closed and is able to be printed, every time I edit the code and then test it, it still removes the buffers when I hit the print function I have looked up everything I can think of and I am at a loss. Any help would be appreciated.
DSpencer
Thanks for the input, it was actually a matter of it not deleting an occurrence of the widget every time I made changes to check it so it never took my changes.
LefterisKoumis
Did you add the buffer graphics layer to a graphicslayer? Then, add it to the map. It won't go away and you will be able to print it.
______________________________________
Lefteris Koumis
Senior Transportation Engineer, M.Sc. P.E.
Division of Environmental Analysis.
DSpencer
