create a custom in panel widget problem
7323
12
02-05-2015 05:33 AM
LeeCollier3
Step 5 in the create a custom in panel widget
https://developers.arcgis.com/web-appbuilder/sample-code/create-custom-in-panel-widget.htm
just makes no sense as webapp and sample-configs as well as config-demo.json do not exist.
Does anyone know what the URL should be to test the custom widget
JonathanBailey
BUMP.
Using the latest version of the Web AppBuilder and the current instructions, the URL for testing a widget doesn't work:
http://[your-host]:3344/webappbuilder?config=sample-configs/config-demo.json
Instead, you're just taken to the default Web AppBuilder page.
RobertScheitlin__GISP
Jonathan,
   Replace "webappbuilder" with "webappviewer"
JonathanBailey
Update: Sometimes it works, and sometimes it doesn't. Once I cleared my cache, it eventually worked again. But, it seems that there's a bug in here somewhere that's preventing it from loading the configuration.
