Chart options in webapp builder
1805
02-05-2018 07:43 AM
GUNASEKARANJOSEPH_IRWIN
Is there anyway I can create a chart as follows in the webapp builder?any custom widget available?.
DerekLaw
Esri Esteemed Contributor
Hi Gunasekran,
Charting capabilities in Web AppBuilder are enabled with the Infographic widget,
Infographic widget—Web AppBuilder for ArcGIS | ArcGIS
Although, I don't think it can render exactly what your image shows. I know this is possible in Operations Dashboard for ArcGIS with the Serial Chart element.
Hope this helps,
JOSEPH_IRWINGUNASEKARAN
Hi Derek,
Thank you. It is a mixed chart with a line(Y) and a bar(x) .Is there any way I can insert the js into the chart widget.I don’t know where I can insert my custom code taken from a chart.js
Just as below.
var myChart = new Chart(ctx, {
  type: 'bar',
  data: data,
  options: options
At this point we have a standard bar chart. Now we need to convert one of the datasets to a line dataset.
var mixedChart = new Chart(ctx, {
  type: 'bar',
  data: {
    datasets: [{
          label: 'Bar Dataset',
          data: [10, 20, 30, 40]
          label: 'Line Dataset',
          data: [50, 50, 50, 50],
          // Changes this dataset to become a line
          type: 'line'
    labels: ['January', 'February', 'March', 'April']
  options: options
Please let me know ,if there is any possibilities.
Thank you
Joseph Irwin.
DerekLaw
Hi Joseph,
Sorry, I am not a developer - so I can't help with your question. I suggest you re-post your 2nd post as a new question in this forum, Web AppBuilder Custom Widgets.
Also, since you mentioned,
Ops Dashboard does not support mixed charts. I thought your lines were guideline markings for the bar chart.
Hope this helps,
