System.Windows.Interactivity ?? ArcGIS View Project references this but can't find it
3705
02-13-2012 02:40 PM
Stephen_Bebb
When I create an out of the box ArcGIS Viewer project template it creates all the files and references different assemblies.
One assembly that can't resolve is "System.Windows.Interactivity".  My ArcGIS Viewer project tempalte can't find and resolve this?
I was sure I ran all the installers required. What is the location of this assembly and what installs it?
Thanks in advance
Steve
KatherineDalton
Hi Stephen,
You will need to install the Microsoft" rel="nofollow" target="_blank">http://www.microsoft.com/download/en/details.aspx?displayl... Expression Blend SDK to have access to System.Windows.Interactivity. The default location for System.Windows.Interactivity should be: C:\Program Files\Microsoft SDKs\Expression\Blend 3\Interactivity\Libraries\Silverlight.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
KatherineDalton
Hi Stephen,
Katy
AndreasHoogeveen
Hi Stephen,
You will need to install the Microsoft Expression Blend SDK to have access to System.Windows.Interactivity. The default location for System.Windows.Interactivity should be: C:\Program Files\Microsoft SDKs\Expression\Blend 3\Interactivity\Libraries\Silverlight.
Katy
Mine was located in C:\Program Files (x86)\Microsoft SDKs\Expression\Blend\Silverlight\v4.0\Libraries (perhaps it has something to do with Blend not being installed).
