Relate table fields do not show up in pop-up tool
3960
02-27-2012 02:45 PM
AaronTurecek
When I use the pop-up tool to identify features in a map service, relate table fields do not show up.  Any ideas?
Aaron
KatherineDalton
Hi Aaron,
Support for related tables is not included as part of the ArcGIS Viewer for Silverlight 1.0 release. We�??ll consider this functionality for the next release.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
CliffJones
Katy
Please do!
Cliff
Cliff Jones
GIS Coordinator
Alaska Dept. Environmental Conservation
StephanieSnider
Related tables and relationship classes are critical to retrieving useful data in a GIS.  There are many times when a "field join" simply will not do, such as when you have a one to many relationship.  Please add this functionality to the Silverlight viewer.  I'm still searching for a replacement for the .NET ArcGIS Server Manager.  So far, neither Silverlight or Flex meets our needs which means we cannot upgrade to version 10.1 when it comes out.
SobodhDangwal
Hi Katy
Does the next viewer release due in September October, support related tables?
Thanks
KatherineDalton
All,
We've posted a Query Related Records sample that you can download and use to view the related records of a feature. Once you download the file, you will need to upload the add-in (.xap) in the Builder Settings menu and then add the tool to the Pop-up toolbar. Since this is a sample that is designed for you build upon, there are certain limitations, such as the Relationship ID is hard-coded to be the first relationship that the tool finds, even if there are other relationships available. Please see the Description and Deployment Instructions included in the sample for more information.
Hope that helps,
Katy
