Popup Layer Order
4114
06-05-2013 10:33 AM
GlennNixon
Does anyone know if there is a way to control the order of the Popup. I have several features that overlap, all with Popup's enabled. I assumed that the order would be based on the order of the layers in the map, but this doesn't seem to be the case. Most times i have the bottom most layer and the first Popup window to appear when i click on a given feature.
BrianLeroux
It appears to me that the order is based on the order in which the data for the pop-up is returned. Graphics layers appear to be the fastest and then the dynamic server layers are slower because they are waiting for the identify results to return. Again this is just my observation. If this is the case I am sure a custom pop up behaviour could be developed to accomodate the layer order.
LisCollins
Bumping up. Any other solutions to this problem?
