An option to turn on/off the basemap (rather than playing with the code),
2467
6
05-07-2013 01:03 PM
JamalNUMAN
Legendary Contributor
I???m not sure if there is a setting/option by which one can turn on/off the basemap rather than playing with the code (the same as we have in the flex)
[ATTACH=CONFIG]24109[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
DerekLaw
Esri Esteemed Contributor
Hi Jamal,
I???m not sure if there is a setting/option by which one can turn on/off the basemap rather than playing with the code ...
Please review this help topic: Configuring basemaps
Hope this helps,
DerekLaw
Hi Jamal,
Hope this helps,
JamalNUMAN
Hi Jamal,
Hope this helps,
Many thanks Derek for the help. The link you have provided is very useful. I managed to have my own base map with my local coordinate system. Fantastic.
[ATTACH=CONFIG]24633[/ATTACH], [ATTACH=CONFIG]24634[/ATTACH]
The issue now is that the �??measure�?� tool still uses the long/lat coordinate system. Why it doesn�??t follow the coordinate system set for the base map?
[ATTACH=CONFIG]24635[/ATTACH]
Best
Jamal
Jamal Numan
DerekLaw
Hi Jamal,
FYI, the Measure tool is working as designed: to display point coordinates in lat/long.
Hope this helps,
JamalNUMAN
Hi Jamal,
Hope this helps,
Is there any chance to customize this behaviour such that the measure tool provides the local coordinate system of the base map instead of long\lat
Best
Jamal
Jamal Numan
DerekLaw
Hi Jamal,
Is there any chance to customize this behaviour such that the measure tool provides the local coordinate system of the base map instead of long\lat?
Yes. We've provided the code for the tool: Measure Tool
Hope this helps,
JamalNUMAN
Hi Jamal,
Hope this helps,
Many thanks Derek for the help,
Unfortunately, I�??m not a developer to be able to play with the code. All what I wanted is to let is reads coordinates depending on the coordinate system of the basemap
Best
Jamal
Jamal Numan
