trouble adding enhanced search widget in flex app builder 3.3
2164
06-24-2013 08:28 AM
KirstenLawrence
I'm new to working with flex viewer. I downloaded the esearch files and followed the instructions in the readme file for installing the compiled version in my viewer application folder. When I open the application, I can see the widget, but when I click on it and try to edit, I get this message: Could not find eSearch module for enhanced search widget. I also was a little confused about the instructions of modifying the draw.xml and am unsure I did that correctly, in terms of what I was supposed to paste into it and where. Can anyone help.
RobertScheitlin__GISP
Kirsten,
   If you are using application builder than you would not need to follow the instructions for the compiled viewer. You would follow the instructions for application Builder integration at this link:
http://resources.arcgis.com/en/help/flex-viewer/concepts/01m3/01m30000004m000000.htm
As far as the enhanced draw widget changes you do not need to do this unless you are using my eDraw widget.
