Query popup photo does not display
478
09-25-2013 12:56 PM
MattShetzer
I've noticed that the Query popup with a photo does not seem to be working.  I've tested it in 3.3 and 3.4 with the same results
I've referenced the sample from ESRI for traffic cameras, and the photo does not appear, but when you click the link it opens correctly in a new tab.
Has anyone else seen this behavior?
[ATTACH=CONFIG]27762[/ATTACH]
<?xml version="1.0" ?>
<configuration label="Louisville Traffic Cameras">
    <layer>http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/...</layer>
    <titlefield>DESCRIPTION</titlefield>
    <linkfield>URL</linkfield>
    <fields all="false">
        <field name="DESCRIPTION"/>
        <field name="URL"/>
        <field name="LAST_UPDATED" alias="Updated"/>
    </fields>
    <filterfield>
        <name></name>
        <alias></alias>
    </filterfield>
    <refreshrate></refreshrate>
    <zoomscale>18000</zoomscale>
    <query>1=1</query>
</configuration>
Thank you,
Matt Shetzer
RobertScheitlin__GISP
Matt,
   This is a known issue and is fixed for 3.5. If you use the source code then you can make the change without waiting for 3.5:
https://github.com/Esri/arcgis-viewer-flex/issues/158
MattShetzer
Thanks Robert !!!!
Matt
Matt,
by Anonymous User
Not applicable
I'm not sure about the Query pop-up, but in version 3.4 I am able to display an image in the stanard pop-up using the following code:
[ATTACH=CONFIG]27783[/ATTACH]
<configuration>
    <title>OUTFALL - {Outfall_ID}</title>
    <description><![CDATA[<a href='http://gisfile1.cob.cob.com/flexviewers/WSR/images/Storm_Sewer_Images/OutfallPhotos/{PhotoID}.jpg'>
<img src="http://gisfile1.cob.cob.com/flexviewers/WSR/images/Storm_Sewer_Images/OutfallPhotos/{PhotoID}.jpg" width="240" height="180" />
IMAGE</a>
TYPE: {Subtype}<br />
LOC DESC: {LocationDesc} <br />
DIAMETER: {SIze_Inches}"<br />
SOURCE: {RecordSource}<br />
SHAPE: {Shape_of_Outfall}<br />
CONDITION: {Structural_Condition}<br />
DATE: {Date_Survey}<br />
DICHARGE: {Discharge}<br />
NOTES:{DischargeNotes}<br />
ODOR: {Odor}<br />
COLOR: {Color}<br />
CLARITY: {Clarity}<br />
FLOATABLES: {Floatables}<br />
DEPOSITS: {Deposits}<br />
VEGITATION: {Vegitation}<br />
BIOLOGICAL: {Biological}<br />
COMMENTS: {OtherComments}<br />
]]></description>
    <fields>
        <field name="Outfall_ID" alias="Outfall_ID"/>
        <field name="NumberOnPlan" alias="NumberOnPlan"/>
        <field name="Development" alias="Development"/>
        <field name="DiameterFt" alias="DiameterFt"/>
        <field name="TopOfGrate" alias="TopOfGrate"/>
        <field name="Weir" alias="Weir"/>
        <field name="Invert" alias="Invert"/>
        <field name="RecordSource" alias="RecordSource"/>
        <field name="Avg_Est_Acc" alias="Avg_Est_Acc"/>
        <field name="Wor_Est_Acc" alias="Wor_Est_Acc"/>
        <field name="SIze_Inches" alias="Size (In.)"/>
        <field name="Shape_of_Outfall" alias="Shape_of_Outfall"/>
        <field name="Type_of_Outfall" alias="Type"/>
        <field name="LocationDesc" alias="Location"/>
        <field name="Subtype" alias="Structure Type"/>
        <field name="Rainfall" alias="Rain Fall"/>
        <field name="Discharge" alias="Discharge"/>
        <field name="DischargeNotes" alias="DischargeNotes"/>
        <field name="PhotoID" alias="PhotoID"/>
        <field name="Odor" alias="Odor"/>
        <field name="Color" alias="Color"/>
        <field name="Clarity" alias="Clarity"/>
        <field name="Floatables" alias="Floatables"/>
        <field name="Deposits" alias="Deposity"/>
        <field name="Vegitation" alias="Vegitation"/>
        <field name="Structural_Condition" alias="Structural_Condition"/>
        <field name="Biological" alias="Biological"/>
        <field name="OtherComments" alias="OtherComments"/>
        <field name="Date_Survey" alias="Date_Survey"/>
        <field name="PhotoLink" alias="Photo Link"/>
    </fields>
    <showattachments>false</showattachments>
    <showrelatedrecords>false</showrelatedrecords>
</configuration>
