Popup with Attribute data and  Image
9119
20
12-18-2013 06:01 AM
DustinHolt
I'm trying creating a simple single feature class flex map that will display a pop up window with attribute data and an image in the same window. Basically the same functionality as a feature class with attachments in arcmap when you use the HTML popup tool. I have everything set up properly in Flex application builder but the image only appears as a link in the window. Can anyone give me a push in the right direction?
AnthonyGiles
Honored Contributor
Dustin,
This can be done but it requires changing the source code. If you have the ability to do this you need to change the size in the popuprendererskin.mxml
Regards
Anthony
DustinHolt
Where can I find the popuprendererskin.mxml?
AnthonyGiles
Honored Contributor
Dustin,
It's in the API but this requires editing the source code in something like flash builder, as you started off this thread stating you have been using the application builder are you sure you have the ability to edit and compile the source code?
http://www.esri.com/apps/products/download/index.cfm?fuseaction=download.all#ArcGIS_API_for_Flex
Regards
Anthony
DustinHolt
I do have Flash Builder, and feel fairly comfortable working with code and compiling. I'm just new to Flex.
AnthonyGiles
Honored Contributor
DustinHolt
Thanks Anthony, I'm having uses with Flash Builder right now, but as soon as I get those worked out I'll follow your info.
OlegLukyanov
How can I insert image to Popup from attachment?
Oleg
AnthonyGiles
Honored Contributor
Oleg,
In the popup xml set the <showattachments> to true:
<showattachments>true</showattachments>
See the help here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Pop_up_configuration_files/01m3...
Regards
Anthony
OlegLukyanov
Hi, Anthony
Thank you,
but how can I insert defined image from attachment (#1 or #2) with defined size?
For example I need popup information about the house with large photo of this house or etc.
Oleg
AnthonyGiles
Honored Contributor
Oleg,
The way in which the attachment inspector works is that it shows a thumb nail of the attached document that when clicked opens up. To change the size of the thumb nail would require you to change the code for the attachment inspector, I'm not even sure if you can get to those properties or if the are compiled into the swf. Anybody else know? Robert or Bjorn
Regards
Anthony
