popup windows on Related tables
3434
06-27-2013 03:11 AM
antoniodang
Hello everybody,
I have a shape-file (polygon) and a information-table that is raleted (1-M) and I make it as feature access service, so I can edit the polygon feature.
My problems is I can´t show the attributes of the information table when i select a polygon.
Does anyone have some suggestions for me, im using Flex viewer 3.2
Thx alots for help
Antonio Dang
PiotrSkworzec
When You were configuring popups, did You selected Show related records?
antoniodang
Yes I did.
Here is my config
<?xml version="1.0" ?>
<configuration>
    <title>{Marktyp}</title>
     <fields>
    </fields>
    <showattachments>true</showattachments>
    <showrelatedrecords>true</showrelatedrecords>
</configuration>
RhettZufelt
MVP Notable Contributor
You say so you can edit, so when you say information table, are you refereing to a popup infowindow, or the attribute table widget or edit widet table as they have to be enabled differently.
R_
antoniodang
R_
In polygon shape-file I have a attributes field called "TYPE" which contains all my classifications of the polygon type.
And the dbase table I do have more information about these classifications.
This dbase table is not editable in flex, only the polygon shapes.
So I maked a relationship 1-M between polygon shape-file and dbase.
I dont use table widget. Only edit widget for editing/addning/removing polygon shapes. I have make that a user can only add/edit in field TYPE and COLLECT_DATE.
I want to refereing to a popup infowindow which is builded in the viewer.
So when a user selected a polygon the popup will show information about the classification from the dbase table .
