Google Street View for Flex 3.0
1428
09-19-2012 08:15 AM
TinaCanady
I replaced the index file and the text on the widget buttons have disappeared. When I put my original index back they reappear.  Any help would be appreciated.
CrystalynDelaCruz
I ran into a similar problem.  The text on my map switcher would disappear when I replaced the index with the one included with the widget.  I searched both index files to find what was different and added the following items (in bold) to my index.  That fixed the problem for me.  Hope this helps.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
    <head>
        <title>ArcGIS Viewer for Flex</title>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
        <meta name="description" content="Esri ArcGIS viewer for Flex"/>
        <meta name="keywords" content="Esri, ArcGIS, Flex Viewer"/>
        <meta name="author" content="Esri"/>
        <!-- Include CSS to eliminate any default margins/padding and set the height of the html element and
             the body element to 100%, because Firefox, or any Gecko based browser, interprets percentage as
             the percentage of the height of its parent container, which has to be set explicitly.  Fix for
             Firefox 3.6 focus border issues.  Initially, don't display flashContent div so it won't show
             if JavaScript disabled.
        <style type="text/css" media="screen">
            html, body  { height:100%; }
            body { margin:0; padding:0; overflow:auto; text-align:center;
                   background-color: #ffffff; }
            object:focus { outline:none; }
            #flashContent { display:none; }
        </style>
        <!-- Enable Browser History by replacing useBrowserHistory tokens with two hyphens -->
        <!-- BEGIN Browser History required section >
        <link rel="stylesheet" type="text/css" href="history/history.css" />
        <script type="text/javascript" src="history/history.js"></script>
        <! END Browser History required section -->
        <script type="text/javascript">
            var isIElt9 = false;
        </script>
        <!--[if lt IE 9]>
                isIElt9 = true;
            </script>
        <![endif]-->
<script src="http://maps.googleapis.com/maps/api/js?sensor=false" type="text/javascript"></script>
        <script type="text/javascript" src="widgets/StreetView/streetview.js"></script>
<script type="text/javascript" src="swfobject.js"></script>
            <!-- For version detection, set to min. required Flash Player version, or 0 (or 0.0.0), for no version detection. -->
            var swfVersionStr = "11.1.0";
            <!-- To use express install, set to playerProductInstall.swf, otherwise the empty string. -->
            var xiSwfUrlStr = "playerProductInstall.swf";
            var flashvars = {};
            flashvars.localeChain = "en_US";
            flashvars.resourceModuleURLs = "assets/locale/en_US.swf";
            //flashvars.localeChain = "ar";
            //flashvars.resourceModuleURLs = "assets/locale/ar.swf";
            //flashvars.localeChain = "de_DE";
            //flashvars.resourceModuleURLs = "assets/locale/de_DE.swf";
            //flashvars.localeChain = "es_ES";
            //flashvars.resourceModuleURLs = "assets/locale/es_ES.swf";
            //flashvars.localeChain = "fr_FR";
            //flashvars.resourceModuleURLs = "assets/locale/fr_FR.swf";
            //flashvars.localeChain = "it_IT";
            //flashvars.resourceModuleURLs = "assets/locale/it_IT.swf";
            //flashvars.localeChain = "ja_JP";
            //flashvars.resourceModuleURLs = "assets/locale/ja_JP.swf";
            //flashvars.localeChain = "ko_KR";
            //flashvars.resourceModuleURLs = "assets/locale/ko_KR.swf";
            //flashvars.localeChain = "nb_NO";
            //flashvars.resourceModuleURLs = "assets/locale/nb_NO.swf";
            //flashvars.localeChain = "nl_NL";
            //flashvars.resourceModuleURLs = "assets/locale/nl_NL.swf";
            //flashvars.localeChain = "pl_PL";
            //flashvars.resourceModuleURLs = "assets/locale/pl_PL.swf";
            //flashvars.localeChain = "pt_BR";
            //flashvars.resourceModuleURLs = "assets/locale/pt_BT.swf";
            //flashvars.localeChain = "ro_RO";
            //flashvars.resourceModuleURLs = "assets/locale/ro_RO.swf";
            //flashvars.localeChain = "ru_RU";
            //flashvars.resourceModuleURLs = "assets/locale/ru_RU.swf";
            //flashvars.localeChain = "sv_SE";
            //flashvars.resourceModuleURLs = "assets/locale/sv_SE.swf";
            //flashvars.localeChain = "zh_CN";
            //flashvars.resourceModuleURLs = "assets/locale/zh_CN.swf";
            var params = {};
            params.quality = "high";
            params.bgcolor = "#ffffff";
            params.allowscriptaccess = "sameDomain";
            params.allowfullscreen = "true";
            var isAIR = navigator.userAgent.indexOf("AdobeAIR") != -1;
            if (isAIR || isIElt9)
                // workaround for overlaying tool tips and other content when loaded into an AIR app
                // workaround for cursor issue - https://bugs.adobe.com/jira/browse/SDK-26818
                params.wmode = "opaque";
            var attributes = {};
            attributes.id = "agsview3";
            attributes.name = "agsview3";
            attributes.align = "middle";
            swfobject.embedSWF(
                "index.swf", "flashContent",
                "100%", "100%",
                swfVersionStr, xiSwfUrlStr,
                flashvars, params, attributes);
            <!-- JavaScript enabled so display the flashContent div in case it is not replaced with a swf object. -->
            swfobject.createCSS("#flashContent", "display:block;text-align:left;");
        </script>
    </head>
    <body>
        <!-- SWFObject's dynamic embed method replaces this alternative HTML content with Flash content when enough
             JavaScript and Flash plug-in support is available. The div is initially hidden so that it doesn't show
             when JavaScript is disabled.
        <div id="flashContent">
            <p>
                To view this page ensure that Adobe Flash Player version
                11.1.0 or greater is installed.
            </p>
                var pageHost = ((document.location.protocol == "https:") ? "https://" : "http://");
                document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='"
                                + pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" );
            </script>
        </div>
        <noscript>
            <object id="agsview3" name="agsview3" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="100%" height="100%" id="index">
                <param name="movie" value="index.swf" />
                <param name="quality" value="high" />
                <param name="bgcolor" value="#ffffff" />
                <param name="allowScriptAccess" value="sameDomain" />
                <param name="allowFullScreen" value="true" />
                <!--[if !IE]>-->
                <object type="application/x-shockwave-flash" data="index.swf" width="100%" height="100%">
                <!--<![endif]-->
                <!--[if gte IE 6]>-->
                    <p>
                        Either scripts and active content are not permitted to run or Adobe Flash Player version
                        11.1.0 or greater is not installed.
                    </p>
                <!--<![endif]-->
                    <a href="http://www.adobe.com/go/getflashplayer">
                        <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash Player" />
                    </a>
                <!--[if !IE]>-->
                </object>
                <!--<![endif]-->
            </object>
        </noscript>
   </body>
</html>
RobertScheitlin__GISP
All,
   Here is a new Google Street View Widget:
http://forums.arcgis.com/threads/86574-Google%C2%AE-Street-View-Widget
