Flexviewer3.4 would like clear result graphic after zoom?
1335
8
09-04-2013 05:16 AM
haThach
Can anyone point me to the right direction? I am using a regular search widget 3.4, where do I go about clearing the result graphic polygon layer when I hover over the result, click once to zoom to extent, then clear or fade away the result graphic.
[ATTACH=CONFIG]27194[/ATTACH]
RobertScheitlin__GISP
ha Thach,
   Clicking the little trash can icon clears the graphic and results. There is nothing built in for what you are asking for.
haThach
Thanks Robert,
What I really want is able to config the mxml adding a clear graphic function in an area to automatically clear the result graphic after zoom to the extent.
ha Thach,
   As I mentioned there is NO configuration for this. You can add this capability to the code if you are working with the source code in Adobe Flash Builder though.
haThach
Robert,
Yes, I'm working with the source code in Adobe Flash Builder 4.7, can you point me to a specify area in the source code. Thanks.
ha Thach,
Here is what I would change/Add:
            private function showHighlight(params:Array):void
                var searchResult:ResultItem = params[0];
                var showHighlightPoint:MapPoint = searchResult.center as MapPoint;
                var linkAlias:String = searchResult.attributes.linkAlias;
                popUpRenderer.popUpInfo = configurePopUpInfo(searchResult.attributes);
                popUpRenderer.graphic = searchResult.graphic;
                map.infoWindow.content = popUpRenderer;
                map.infoWindow.contentOwner = popUpRenderer.graphic;
                map.infoWindow.show(showHighlightPoint);
                clearTimeout(hitimer);
                hitimer = setTimeout(clearGraphics, 300);
            private function clearGraphics():void
                if (resultFeatureLayer)
                    resultFeatureLayer.featureCollection = new FeatureCollection(new FeatureSet(), resultFeatureLayer.layerDetails); // empty featureset to clear
haThach
Robert, the code work great. Once again, you are very helpful, Thank You!
ha Thach,
   Glad to help. Now you need to do your part and follow these instructions:
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
ha Thach,
  OK you are half way there... Now just do step 1 in the graphic above
