Sending a pdf by email
2300
08-13-2011 11:33 PM
ZarehDemirdjian
Dear All,
I am developing a web application using the ArcGIS API for Flex and i used the ArcGIS viewer for Flex, i have a send email widget in which you can either save the display of the map and the routing directions that you chose in a pdf, or send the pdf by email, the problem is that i cant send the pdf by email unless i have saved it first...is there a way that i can send the pdf via email but without having to save it 1st?? or can i hide the save dialog box so once the user clicked at send by pdf it automatically saves it and send it by email???
I appreciate your help..
Zareh
sobarim-amin
Dear Zareh,
Can you share your sending email widget/code?
Regards,
Sobari
