OK. That seemed to fix the original problem. Specifically, I added the URL below to the <taskurl> element in GeoprocessingWidget_ExtractData.xmlhttp://SERVER.NAME/ArcGIS/rest/services/ClipAndShip/GPServer/Extract%20Data%20TaskNow. I am getting the following errorerror Object { code=500, message="Error Submitting Job", details=[0]}http://SERVER.NAME/ArcGIS/rest/services/ClipAndShip/GPServer/Extract%20Data%20Task/submitJob?Feature%5FFormat=Shapefile%20%2D%20SHP%20%2D%20%2Eshp&Layers%5Fto%5FClip=%5B%22Wetlands%22%5D&env%3AoutSR=102100&f=json&Area%5Fof%5FInterest=%7B%22features%22%3A%5B%7B%22geometry%22%3A%7B%22rings%22%3A%5B%5B%5B%2D9223944%2E457536787%2C4121207%2E8665091326%5D%2C%5B%2D9223944%2E457536787%2C4144444%2E723107815%5D%2C%5B%2D9204070%2E830182651%2C4144444%2E723107815%5D%2C%5B%2D9204070%2E830182651%2C4121207%2E8665091326%5D%2C%5B%2D9223944%2E457536787%2C4121207%2E8665091326%5D%5D%5D%2C%22spatialReference%22%3A%7B%22wkid%22%3A102100%7D%7D%7D%5D%7D
I am having the same issue on my server. I am using the same ClipAndShip example. Have you figured out how to fix this problem?This is my syntax:"http://server.name/ArcGIS/rest/services/ODRG/ClipandShip/GPServer/Extract Data Task/submitJob?f=json&env:outSR=102100&Layers_to_Clip=["Art_Cat","Art_Cat","Art_Cat"]&Area_of_Interest={"fields":[],"geometryType":"esriGeometryPolygon","features":[{"geometry":{"rings":[[[-13594793.76432079,6051782.877430132],[-13594793.764320793,6051769.739815896],[-13594791.375663659,6051849.759829876],[-13594740.019535283,6051836.622215641],[-13594793.76432079,6051782.877430132]]],"spatialReference":{"wkid":102100}}}],"sr":{"wkid":102100}}&Feature_Format=Shapefile - SHP - .shp&callback=dojo.io.script.jsonp_dojoIoScript5._jsonpCallback"I get this error: dojo.io.script.jsonp_dojoIoScript5._jsonpCallback({"error":{"code":500,"message":"Error Submitting Job","details":[]}});Dave S
