Extract data widget, clip and ship problem
2441
12-02-2011 06:36 AM
AndreyZhalnin
Hello all,
Need help with Extract Data widget for Flex. I created "clip and ship" AGS service for feature data based on "Extract Data Task" provided in ArcGIS10. Task uses ExtractData.py script from ArcGIS10. GP service works fine with ArcGIS10 on remote machine when connected as GIS service. However when used in ExtractData widget for AGS Flex Viewer 2.4, it produces the following error (as seen in AGS error log):
Executing (ExtractData): ExtractDataTask2 'Agribusiness, Food Processing & Technology, 2010' "Feature Set" "File Geodatabase - GDB - .gdb" "USA Contiguous Albers Equal Area Conic USGS" \\********\arcgisserver\arcgisjobs\ndm_extractdata2_gpserver\jb2d7b4806df84fcb8b84d1eac020b81f\scratch\output.zip Start Time: Fri Dec 02 10:58:47 2011 Executing (Extract Data): ExtractData 'Agribusiness, Food Processing & Technology, 2010' "Feature Set" "File Geodatabase - GDB - .gdb" "ESRI GRID - GRID" "USA Contiguous Albers Equal Area Conic USGS" \\********\mxd\GP_Tools\SpatialReference \\********\arcgisserver\arcgisjobs\ndm_extractdata2_gpserver\jb2d7b4806df84fcb8b84d1eac020b81f\scratch\output.zip Start Time: Fri Dec 02 10:58:48 2011 Running script ExtractData... ERRORS: Traceback Info: File "E:\Installed\ArcGIS\Server10.0\ArcToolbox\Scripts\ExtractData.py", line 325, in zipFolder = clipAndConvert(layers, areaOfInterest, featureFormat, rasterFormat, coordinateSystem) Error Info: : exceptions must be old-style classes or derived from BaseException, not str Completed script ExtractData... Failed to execute (Extract Data). Failed at Fri Dec 02 10:58:49 2011 (Elapsed Time: 1.00 seconds) Failed to execute (ExtractData). Failed at Fri Dec 02 10:58:49 2011 (Elapsed Time: 2.00 seconds)
Looks like something is going on with Python script?
Any help is appreciated
Thank you
Andriy
