Charts and Flex 4.6 SDK
1334
11-30-2011 09:01 PM
AndrewLeane1
I just installed Flash Builder 4.6 today and noticed that some of my 2.4 widgets weren't showing at all in the viewer. Most widgets made the migration across fine, so I narrowed it down to just those that had a chart component. No errors though, the widget just fails to show up (but takes up space in the widget container). If I comment out the mx:chart component, the widget loads fine.
Anyone else seeing a similar issue with the 4.6 sdk?
For now I am using the 4.5.1A sdk in Flash Builder 4.6, and then all the chart widgets work just fine.
DasaPaddock
See the workaround in the 2.5 Viewer's Chart widget and please vote for:
https://bugs.adobe.com/jira/browse/FLEXDMV-2689
BjornSvensson
Esri Alum
FYI, since we now have the Flex Viewer source code in GitHub, you can easily see the Chart Widget source code at https://github.com/ArcGIS/ArcGISViewerForFlex/blob/master/src/widgets/Chart/ChartWidget.mxml
ReneRubalcava
Esri Frequent Contributor
I just have to say, it's real nice to see flexviewer source on github. Makes things simpler.
