Dynamic Legend picture fill hatch symbology
1548
20
12-08-2010 07:22 PM
IanHamilton
Hi , Has any one managed to get the dynamic legend widget the show these types of legend colours.
I can only get a solid fill colour no matter what I publish?
Or is there an alternative legend I cuold use?
WallaceBezerra
New Contributor II
I'm using the SOAP API to fetch all the hatch symbology. They come as an ByteArray and you can set the source property of a spark image control to show them on screen.
If you need a detailed explanation, let me know.
RobertScheitlin__GISP
Ian,
   I will test my dynamic legend against all possible symbol type and create a map service that demo all that work and details the ones that do not because of REST Endpoint limitations.
Ian,
   So it looks like even with ArcGIS Server SP1 the REST Endpoint is still having issues with Polygons:
  1. Gradient Fill Symbols
  2. Marker Fill Symbols
  3. Line Fill Symbols
  4. Anything Composite
Lines:
  1. Hash Line Symbol
  2. Picture Line Symbol
  3. Marker Line Symbol
What the dynamic legend uses is the drawingInfo from the REST Endpoint and that is where it is having issues.
All of this is actually fixed in SP1 if you use the new legend endpoint like this one
http://gis.calhouncounty.org/ArcGIS/rest/services/Symbols/MapServer/legend
But I will have to re-write the dynamic legend to use this new feature and then of course require SP1
IanHamilton
I'll await the result of your endeavours!
AshleyOwens
New Contributor II
Robert, can you repost the link to the updated dynamic legend code? That link was broken for me. This widget is great! The only thing I'm having trouble with is hatched polygons showing as solid, so I'd love to get the updated code.  Thanks!
Ashley,
   All you need to do is check the code gallery.
http://www.arcgis.com/home/item.html?id=f60406b9f52340d59eb557bf64136af6
AshleyOwens
New Contributor II
Robert,
That's the version I'm currently using - does it have the hatched polygon fix? Mine are still showing as solid.
Ashley
Ashley,
   Do you have ArcGIS Server 10 SP1 or greater?
