Coordinate Widget
2334
8
10-22-2010 12:42 PM
JoshuaCoates
I successfully added the coordinate widget to my flex map and am just trying to find out why the values are so large for the Lat. & Long.? The CoordinateWidget.xml looks like this:
<configuration>
    <!-- geo, dms, mercator -->
    <outputunit>geo</outputunit>
    <numberformatter precision="6"/>
    <label template="Latitude:{1}   Longitude:{0}"/>
</configuration>
For some reason, this county that is in Georgia has lat/long values that are HUGE....lat:1526227.083333 & long:2062602.444444. Why are the lat/long 7 numbers before the decimal? Shouldnt it be lat:34 and long:-84 or something around there??
Josh C.
RobertScheitlin__GISP
Josh,
   Webmercator is UTM not geographic so those values are correct since Webmercator coordinates are in meters.
DasaPaddock
If the spatial reference of your map is web mercator, then it will convert to geographic. Try running config-all.xml for an example.
If the spatial reference of your map is geographic, then no conversion is required, but if it's something else, you won't see geographic values.
JoshuaCoates
It is actually Tranverse Mercator, State Plane...So i suppose this is how it is going to show the latitude and longitude...in meters? No big deal, I am not sure why I thought it might show degrees of latitude and longitude. Thanks for your clarification!
Josh C.
JoshuaCoates
If the spatial reference of my map is transverse mercator, is there not a way that the coordinate widget can convert to decimal degrees and show DD for the lat./long.? Is seems like this is something that should be manageable....
Joshua,
    The client side code does not have the ability to re-project coordinates from StatePlane to geographic natively. ESRI probably will not add client side re-projection to the API as the API is free and that would be a significant investment of man-hours to do and then to maintain.
JoshuaCoates
Ok, thanks. So it is just going to have to be shown in meters then?! I didnt know if it was possible that the coordinate widget could just convert from stateplane to decimal degrees. I had no idea that it would have to completely re-project the map. I just thought there were equivalent values from stateplane that could be converted to the decimal degree location?!
Joshua,
   Yes it would just have to re-project the point coordinate of the mouse and not the map, but that still leads to the fact that the client side code does not know how to do this, and it would take a round trip to the server every pixel that the mouse move in order to do this.
JayGeisen
Dasa/Robert,
Wouldn't it be possible to have a tool that would only re-project to geographic values on mouse click only instead of continuously?  How difficult would this be to do?  Does this exist already?
Jay
