Three (or four) base layers, none of them arcgis online default layers.
1342
7
10-26-2010 06:28 AM
jameshawks
I want to have thee (for now, may try four if this works) base layers. All of them are dynamic and the same projection. I don't wan't any of the ags online default layers (streets, topo, imagery). There's plenty of other places to get those views, besides my overburdened site. I can get my three base layers to show, but if I comment out all the default base layers, the site breaks.
RobertScheitlin__GISP
James,
   Are you making sure you change the initial extent values of the map to match your basemaps coordinates?
jameshawks
Yes, I think. I modified the initial extent but kept it in the same format.
<map initialextent="-15083000 3139000 -4779000 5458000" top="40">
James,
   If you go to your REST Service directory for your largest base map service are those similar to the ones listed there for the initial extent?
jameshawks
hmm no those are this format:
Initial Extent:
XMin: -77.06190689709936
YMin: 33.39085275237296
XMax: -57.931040410223915
YMax: 51.42716717656648
Spatial Reference: 4326
Initial Extent:
XMin: -159.70283644018508
YMin: 5.917255388422404
XMax: -44.414534502768305
YMax: 78.0625130851965
Initial Extent:
XMin: -172.4516129032258
YMin: -5.05527154617904
XMax: -52.6384872080089
YMax: 92.29289308118469
jameshawks
Okay I'm close. Adding decimal points to the initial extent allows me to see the 3 base layers. However the zoom slider isn't fully functional now. It's collapsed and lost it's ticks. See image.
James,
    Yep that is expected as the zoom slider only displays tick for map services that are tiled/cached and your are dynamic right now.
jameshawks
Okay. Well that's more incentive to go tiled. I gotta say I don't much about it yet, research time.
For the next trick, I want to swap the layer list as the user swaps services. That sounds tricky, at best.
