Changing the size of pop-up windows
873
06-16-2011 07:53 AM
KarlWilson
Is it possible to change the size of the pop-up windows? I can't see anywhere where it is defined.
Karl
JustinRobinson
Hi Karl,
It is possible, but requires editing the popUp skin. This can be somewhat of a pain but is entirely doable. This thread has some information on how to accomplish this.
Or if you don't want to do some of the manual work, you can grab my field+description popUp modification as a base and edit it from there (remember to add the widget as a flex module under project: properties: flex modules.)
KarlWilson
Thanks Justin, it does seem like a bit of a pain to do something seemingly simple.
I'll give it a try.
Karl
