Buffer distance widget+problem
775
06-26-2013 10:50 PM
anjelinaponker
Hi
I,m using buffer distance widget (Flex 3.3 and ArcGIS 10.1 sp1) and it return this error :
[RPC Fault faultString="Error executing buffer" faultCode="500" faultDetail=""]
What is my widget problem?
Regards
AnthonyGiles
Honored Contributor
Anjelina,
It looks like the geometry service you are using is not returning a result or cannot be found. Check the URL of your geometry service in your main config file.
Regards
Anthony
AnthonyGiles
Honored Contributor
Anjelina,
Regards
Anthony
