edraw+problem
2461
06-26-2013 10:43 PM
anjelinaponker
Hello
I,m using eDaraw widget, when I use add point, the widget return this error:
FaultEvent fault=[RPC Fault faultString="Error executing project" faultCode="500" faultDetail=""] messageId=null type="fault" bubbles=false cancelable=true eventPhase=2
What should I do?
Regards
AnthonyGiles
Honored Contributor
Anjelina,
It looks like the geometry service you are using is not returning a result or cannot be found. Check the URL of your geometry service in your main config file.
Regards
Anthony
AnthonyGiles
Honored Contributor
Anjelina,
Regards
Anthony
