AVL Widget
2737
10-28-2010 07:32 AM
KellyFritz
has anyone heard of a AVL widget?
MikeHargreaves
As in vehicle tracking...?
ToddZimmerman
If the vehicle data you are tracking is in a database table with Lat/Long coodinates, you can publish that as a map service by adding the table to an ArcMap document and using the Display X/Y Data to make it into a map layer. Then use the Query Widget to display the layer and set the refresh rate to however often your data updates.
