sharing data between widgets (using fetchSharedData)
3555
11-02-2010 11:11 AM
MOHANA_KRISHNAPUNNAM
I am working on FlexViewer 2.x. I am using addSharedData to add the data into Datamanager.
It didn't work for me when I am trying to get the data in other widget using fetchShareddata();
In Datamanager.as file I found a function for adding the data. I changed event.data.data to event.data.collection (Line 73). It worked fine for me.
Is it a  bug in the flexViewer?
private function addData(event:AppEvent):void
        var key:String = event.data.key;
        if (key != "")
            var dataCollection:Object = event.data.data;            if (dataTable.containsKey(key))
                dataTable.remove(key);
            dataTable.add(key, dataCollection);
            var data:Object =
                    key: key,
                    data: dataTable
            ViewerContainer.dispatchEvent(new AppEvent(AppEvent.DATA_NEW_PUBLISHED, data));
Thank you,
Mohan
RobertScheitlin__GISP
Mohan,
   Yep it is a bug that I reported back in beta that has yet to be fixed. No big deal though because the only ones using this capability are programmers that can easily fix it themselves.
