An issue when I click on the zoom button of my widget
1732
6
06-15-2012 08:34 AM
AlaeddineSaadaoui
Hi all,
I have an issue with the zoom button of my widget. When I click on the button, the widget goes a little bit far from my point. I am using the following code for zooming:
var here:MapPoint = map.toMap(new Point(map.infoWindow.anchorX, map.infoWindow.anchorY));
if (map.scale > zoomScale)
map.scale = zoomScale;
map.centerAt(here);
I would like to know how I could fix this problem.
Thank you for your help.
AlaeddineSaadaoui
Sorry for the bad code. Maybe the quickest way to test my idea is to center your map first and then to scale. This will cause the event to fire after the map is manipulated.
As for the type error, I was wrong about the arguments needed for the extent change event. I would investigate the api at http://help.arcgis.com/en/webapi/flex/apiref/index.html
Hi ploebus,
I used the code zoomToButton_clickHandler found in the PopUpRenderSkin.mxml and it worked.
Thank you very much for your help.
by Anonymous User
Not applicable
Original User: ploebus
In the older viewer, the infoPopup listens for the extent event and changes its location accordingly. When you set the map scale to the zoom scale, this fires the extent event, but than you further manipulate the map by setting its center which does not fire the event. Maybe this is why the infowindow is offset from the point?
AlaeddineSaadaoui
Hi ploebus,
In this case, how could I change my code to fix this issue?
by Anonymous User
Not applicable
If this is the cause, I think you could center the map first and then zoom to new extent
or
you could manually dispatch the ExtentEvent.EXTENT_CHANGE to force infopopup to change location.
map.dispatchEvent(new ExtentEvent(ExtentEvent.EXTENT_CHANGE));
AlaeddineSaadaoui
or
Hi ploebus,
I have change my code to look like the following:
protected function zoom_clickHandler(event:MouseEvent):void
    map.centerAt(here);
But I got this error:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.ags.tools::NavigationTool/extentChangeHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/dispatchEvent()
at widgets::StructureInfoWidget/zoom_clickHandler()
at widgets::StructureInfoWidget/__buttons_zoomToBtnClicked()
at widgets::AttRelateInfoButtons/zoomToBtn_Click()
at widgets::AttRelateInfoButtons/__zoomToBtn_click()
Thank you.
by Anonymous User
Not applicable
AlaeddineSaadaoui
Hi ploebus,
