Get length of line in EDIT Widget
439
06-20-2012 10:03 AM
SaugatJoshi
Hi all,
How can I proceed of getting a length of a polyline using Edit Widget, similar to the way we get length in Draw and Measure Tool. I need to display the length of the line on map once I complete drawing it with the Edit widget.
Thank you.
AHay
I assume what you are trying to do is show the length of the line as a label after you have created it with the edit widget.  You cannot label features from a feature service,
You will need to create a second map service with the features in it, make them have no symbology add that to your map and it will then label them
