Add checkbox to splash screen to not show
1494
14
12-20-2010 08:54 AM
RichardButgereit
Has anybody thought about adding a check box to the Splash Screen so that once displayed, a user can elect to not have the it displayed the next time they visit the site?
AYounas
Hi Rob,
Thanks for your kind help.
I tried it and my Close function now looks like:
protected function btnClose(event:Event):void
    var btn:Button = new Button();
    if(checkBox.selected)
     btn.enabled =true;
    else
     btn.enabled=false;
     //swidget.dontShowSplashAgain(true);
    PopUpManager.removePopUp(this);
When I run my application, my enable button is disabled because in addButtons function I made it:
switch (btnAction)
      case "close":
       btn.enabled = false;
       btn.addEventListener(MouseEvent.CLICK, btnClose);
       break;
When I click on check box, means its value is selected it should actually make button enable. Any help please.
Sorry if its too basic as I am still learing about widgets.
A
RobertScheitlin__GISP
Adi,
   More like this:
                //If the close button is not enabled we would never get here in the first place.
and
                    switch (btnAction)
                        case "close":
                            btn.enabled = checkBox.selected;
                            break;
AYounas
Thanks again Rob.
I tried exactly as suggested but the Agree button stays disabled even if I check the checkbox:
switch (btnAction)
      case "close":
       break;
and
     btn.enabled =checkBox.selected;
Checkbox
<s:VGroup horizontalAlign="center" verticalAlign="middle" gap="5" width="100%">
   <s:CheckBox id="checkBox" selected="false" label="I accept Terms and Conditions." />
   <s:HGroup id="bGroup" horizontalAlign="center" verticalAlign="middle" gap="10" width="100%"/>
  </s:VGroup>
Any other suggestion please?
Thanking you in advance.
Adi,
   Hmm... That was a little more difficult then I thought it should be...
<s:CheckBox id="checkBox" selected="false" label="I accept Terms and Conditions." change="checkBox_changeHandler(event)"  />
            protected function checkBox_changeHandler(event:Event):void
                for (var b:int = 0; b<bGroup.numElements; b++){
                    if (Button(bGroup.getElementAt(b)).name == "")
                        Button(bGroup.getElementAt(b)).enabled = checkBox.selected;
Once again there is no need to have anything in the btnClose function because it will not get fired if the button is not enabled.
AYounas
Adi,
Excellent!!! That is what I wanted! Thanks alot.
Adnan
