protected function btnClose(event:Event):void
var btn:Button = new Button();
if(checkBox.selected)
btn.enabled =true;
else
btn.enabled=false;
//swidget.dontShowSplashAgain(true);
PopUpManager.removePopUp(this);
}switch (btnAction)
case "close":
btn.enabled = false;
btn.addEventListener(MouseEvent.CLICK, btnClose);
break;
} protected function btnClose(event:Event):void
//If the close button is not enabled we would never get here in the first place.
} switch (btnAction)
case "close":
btn.enabled = checkBox.selected;
break;
switch (btnAction)
case "close":
break;
}protected function btnClose(event:Event):void
btn.enabled =checkBox.selected;
}<s:VGroup horizontalAlign="center" verticalAlign="middle" gap="5" width="100%"> <s:CheckBox id="checkBox" selected="false" label="I accept Terms and Conditions." /> <s:HGroup id="bGroup" horizontalAlign="center" verticalAlign="middle" gap="10" width="100%"/> </s:VGroup>
<s:CheckBox id="checkBox" selected="false" label="I accept Terms and Conditions." change="checkBox_changeHandler(event)" />
protected function checkBox_changeHandler(event:Event):void
for (var b:int = 0; b<bGroup.numElements; b++){
if (Button(bGroup.getElementAt(b)).name == "")
Button(bGroup.getElementAt(b)).enabled = checkBox.selected;
Adi,
Hmm... That was a little more difficult then I thought it should be...<s:CheckBox id="checkBox" selected="false" label="I accept Terms and Conditions." change="checkBox_changeHandler(event)" /> protected function checkBox_changeHandler(event:Event):void { for (var b:int = 0; b<bGroup.numElements; b++){ if (Button(bGroup.getElementAt(b)).name == "") Button(bGroup.getElementAt(b)).enabled = checkBox.selected; } }
Once again there is no need to have anything in the btnClose function because it will not get fired if the button is not enabled.protected function btnClose(event:Event):void { PopUpManager.removePopUp(this); }
