In Real-Time analytics when are data sources refreshed
1377
11-17-2022 07:16 PM
BrynR
I've setup a real-time analytic to perform geofencing of live asset locations.
The geofencing zones are defined in a feature layer (hosted in ArcGIS Server and referenced in ArcGIS Online).
I added the geofence zones into the real-time analytic by the choosing 'Sources'->'Feature Layer' option rather than making a 'Feed' to the feature layer.
I noticed when I add a new zone the assets aren't getting flagged when they pass into this new zone.
How often will the real-time analytic check/refresh the feature layer to load the geofencing zones?
PeterNasuti
@BrynR Thanks for reaching out with this question! The short answer is that in a real-time analytic, the sources are only loaded when the real-time analytic is started. To get the latest geofences, you could stop and restart the analytic. Our Velocity operations team stops and restarts real-time analytics at minimum 3x per year with official releases that go out.
If this is insufficient for your use case, the feature layer could instead be configured as a feed that polls for example every 30 minutes or once every hour or two to refresh the join features for your analysis.
We are also reviewing a path to implement a real-time analytic source "refresh" parameter to trigger a source refresh every x hours for this exact case.
PeterNasuti
BrynR
Thanks @PeterNasuti - you put it more clearly than the documentation!
