Which UN rule enforces self-intersecting line topology error and how to disable it
1944
03-02-2020 01:50 PM
JasonVignochi
I was wondering how to disable the self-intersecting lines topology errors in the the Utility Network. I know the error inspector doesn't work for the UN but I can't seem to find this particular topology rule. The documentation seems to think I need to Delete Rule but I'm not sure which of the UN rules enforces self intersecting line.
Thanks for your help.
PaulLeBlanc1
Self-intersecting errors are not tied to the utility network rules (eg Junction-Edge or Junction-Junction); they will always be in error.
Here's a list of all the error codes and suggestions how to resolve.
Error feature management—ArcGIS Pro | Documentation
PaulLeBlanc1
JasonVignochi
Hi I wanted to say thanks for the help. It turns out I did not have the service area covering the spot where the edits were happening so what you would assume should fix the errors was failing. I ported the UN to a new asset package, modified the service territory, then bootstrapped it to a new EGDB and everything was fine.
