Value is incompatible with other selected values - Contingent Value, System maintained field (ISSUBNETWORKCONTROLLER)
1644
04-26-2024 04:11 AM
Ram
I have published Electric utility network service and configured in editing widget in Experience builder.
It has contingent values for phase change field group (refer image 1).
When I tried to create electric device, it created problem (value is incompatible with other selected values). It is because of 'is subnetwork controller' and 'phase change' fields. Problems faced are,
1. NULL values are not showing in editing widget.
2. Even though I made some changes in contingent values so that I can add any values for phase change, it has thrown same error.
3. When I tried to do some changes in form configuration through map viewer, the field 'is subnetwork controller' is not in the list of form elements. I guess since it is not in form elements, it created problem. is it so?
Once I deleted contingency value for phase changes field group, it worked. But it will affect the validation process. What are the other possible ways to resolve this issue without deleting contingency value?
Any possible solutions are appreciable.
MikeMillerGIS
Esri Frequent Contributor
Did you add IsSubnetworkController null to the CAV list?
