Utility Network Esri Solutions Tasks Not Showing Up in Download
2661
7
11-21-2024 01:19 PM
BGEGIS
Hello -
As I follow along with this video to deploy a Utility Network to an enterprise geodatabase (SDE), I’ve noticed that it includes several tasks that were not present when I downloaded the solution from ArcGIS Online.
Where can I find the tasks that were mentioned in the video linked above?
Thank you.
2 Solutions
MikeMillerGIS
Esri Frequent Contributor
We have migrated the task to online help.  For example, if you are using sewer, start here:
https://doc.arcgis.com/en/arcgis-solutions/latest/reference/configure-sewer-data-model.htm
MikeMillerGIS
HazelRiordan
I was not familiar with that video, but just watched it.  Are there any particular tasks that you are stuck on?  Maybe we could help from here.
MikeMillerGIS
BGEGIS
Thank you! I've been using the documentation, and it has been very helpful. Do you have any suggestions on how to rename the features within the dataset before copying the data over to our SDE? We tried using the D_Rename table but haven't had success so far. We are putting the data in an SDE that houses other UNs, so want to make sure the feature names and associated tables are unique.
MikeMillerGIS
BGEGIS
Thank you, this worked.
LWedderburn9
Mike,
I was wondering where you find the following "Tasks" for Water Distribution Data Management.
It was discussed in the webinar "ArcGIS Utility Network: Implementation Considerations"(19:15 minute mark).
Webinars | Water - Esri Videos: GIS, Events, ArcGIS Products & Industries
LWedderburn9
