Utility Network Compatibility with Azure SQL
1643
05-21-2024 12:53 PM
TSmith
Hello all,
I was curious if Utility Networks are compatible with Azure SQL. I have not seen any information confirming or denying at this point. Setting up an Azure-SQL managed instance is quite different from a standard MSSQL Server install, so I am curious if there are any nuances/issues. Any information is appreciated, thank you!
MarceloMarques
@TSmith
Utility Network requires an ArcSDE Geodatabase.
The ArcSDE Geodabase can be created in SQL Server.
ArcGIS 11.2 and ArcGIS Pro 3.2 requirements for Microsoft SQL Server—ArcGIS Enterprise | Documentati...
FAQ: What SQL Server Database Versions Are Supported by ArcGIS Enterprise and ArcGIS Pro? (esri.com)
The ArcSDE Geodatabase is supported in the Azure SQL Database.
ArcGIS Enterprise in the cloud—ArcGIS Enterprise in the cloud | Documentation for ArcGIS Enterprise
Requirements for using ArcGIS with databases in the cloud
Limitations
If you do not use or cannot use the Esri cloud deployment tools to create the database, and you want to create a geodatabase in any of the supported database-as-a-service offerings listed above, you must use the Enable Enterprise Geodatabase geoprocessing tool to create a geodatabase. Do not use the Create Enterprise Geodatabase tool.
Operating system authenticated connections are not supported from ArcGIS clients to database-as-a-service offerings. Microsoft Azure Active Directory options are available when connecting to Azure SQL Database or Azure SQL Managed Instance.
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
@TSmith
Limitations
I hope this helps.
