Update Error Inspector: it shows deleted items
659
12-22-2022 07:43 AM
Spatial_Fabio
Hi there,
I'm using Arcgis PRO 2.9.1 with Utility Network version 5 (Telco model from Foundation).
I created a point object (Splitter) then attribute rules were triggered and created the structure of associated items as Equipment and Port Groups.
After that I changed the asset type to Splice Enclosure. This object doesn't have the same structure in fact it does not have equipment and an error occured. So I removed the assocations and deleted the objects from the table of non-spatial object but the error inspector still showing records.
I've tried to export associations to csv and those GUID don't exist.
Is it a bug or can I update Error Inspector to current situation? I noticed that the right tab "Details" is empty while for real error it shows more records.
