UN Migration Toolset not honoring Asset Type field input
1483
10
12-10-2025 09:53 AM
NathanGEOregon
Working on our Water UN Prototype, and have successfully delineated all of our primary pressure zones. That felt like a big milestone! I’ve now gone back to the drawing board (re-running Migrate to Utility Network) to try to assign Asset Types to our Water Valves so that I can set Pressure Reducing Valves as subnetwork controllers for delineating our closed PRV subnetworks.
The tool seems to run fine using our “Valve Function” field as the Asset Type input. But after the tool completes, all water valves still have “Water_Valve” as the Asset Group and Asset Type. It’s not splicing or dicing the Asset Type based on the Valve Function field as I expected.
Edit: I do see that it is possible to add Asset Types without needing to "start over" but I kind of want to see how the process goes rebuilding the UN from scratch with the cleanup that I completed thus far.
Any thoughts or recommendations are appreciated!
NathanGEOregon
It worked after I mapped the string data over to a new Integer field and created an Integer coded domain and re-ran the Migrate to Utility Network tool.
(I did download the Utility Network Tools 3.3.3 as Mike recommended, but still had the same issue when using the string field and coded domain)
